주요 콘텐츠로 건너뛰기
No power going to hot water tank - Solved
Why would my hot water tank not be getting power
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
Gas or electric? Make & model number?
It is electric gsw I replaced the elements and thermostat but not getting power at all.
Thank you had someone in today I had to replace the box
댓글 달기
답변 1개
선택된 답변
Use a multimeter and test the breaker box then the electrical wall outlet. If it is working, you probably have a loose or disconnected wire. Great care should be taken when looking or testing for it. I would unplug it and start testing for continuity of the input wires.
Digital Multimeter
Digital Multimeter 이미지
상품
Digital Multimeter
$19.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thank you. It is wired right to the box
댓글 달기
귀하의 답변을 추가하세요
Laura 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 146
