How to recover the OS on my iMac
What method do I need to use to recover the OS with a mid 2011 27" iMac?
The original HDD failed and I’m replacing it with a new SSD. I have a time machine backup on an external SSD. Thanks much!
좋은 질문 입니까?
좋은 질문 입니까?
First you should review this doc Mac startup key combinations and drill down on the Command (⌘)-R links to make sure you can use Internet recovery. Depending on the OS-X/MacOS version your system has you may not have it.
Here’s a good reference on the different recovery options:
So basically, you can leverage the OS which is on your TimeMachine backup or use Internet Recovery. If your internet connection is not very fast I would recommend using the TimeMachine method. To make things easier next time I would recommend spending the effort to create a OS installer USB thumb drive following this guide How to create a bootable macOS Sierra installer drive. I do recommend you stick with Sierra as the highest version of MacOS as High Sierra has issues with SATA based SSD’s as the installer will upgrade the file system to APFS which has issues with SATA based drives and is not compatible with HFS+ volumes.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 400
