주요 콘텐츠로 건너뛰기
The Shark IONFlex 2X (model IF251) is a lightweight, cordless vacuum. It includes the handheld vacuum, motorized floor nozzle, wand, and two rechargeable lithium ion batteries.
16 질문 전체 보기
Brush roll removal possibility
Is it possible to remove and replace the hard brush roll?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
It looks like you can remove it:
  1. Remove both brush roll bands (use existing guides)
  2. Remove the two screws near the left end of the hard brush, the one with a large white gear.
  3. Slide the long thin flat brush on the bottom out through the side
  4. Lift the two metal wires you just exposed supporting the hard brush on the bottom
  5. Push the hard brush from the right end and it should slide right out.
I haven’t found replacement parts for it yet, and the hard-to-reach parts where hair might gather that are still hard to reach unfortunately.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Paul skinner 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 353
