주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2015년 5월 업데이트에는 5 세대 Intel Core i5 및 i7 프로세서가 성능과 배터리 수명을 약간 향상시켰습니다.
623 질문 전체 보기
Doesn't turn on after water spill
My daughter spilled water on laptop. It won’t boot up. No glow from adapter. Took the back cover off and took out the battery. Still won’t boot up, still no glow from adapter but the fan runs. Any suggestions? Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
A working laptop after a spill would be the exception rather than the rule. These are the steps you can try by yourself:
MacBook water damage - The definitive guide
You might need to replace also the keyboard, trackpad, battery, I/O board, logic board and the screen assembly..hard to tell without the chance to evaluate damage and testing. Here you can find the relevant replacement guides:
MacBook Air 13" Early 2015
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
In my case, when I had the problem, the macbook did not turn on about 1 month. after that I took SSD out (macbook air 2013) and put the same one in and everything works well...
댓글 달기
귀하의 답변을 추가하세요
Frank Gill 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 9
전체 시간: 143
