주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Problems with battery calibration
I just replaced the battery on my grandparents iphone 5, but when going to calibrate the battery i found the percentage to at times not move, go down in big chunks and even go up at times. I am struggling to get it to die, and ive tried everything. Any tips?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Was there any power running through the device when you disconnected the original battery?
It’s always worth double checking the connector to make sure it is sitting down correctly, and ofc use an Mfi cable.
If that all checks out then you could have received a faulty battery, if this is the case there should be a warranty and you should be able to get it replaced.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hey thanks for the response, that all did actually check out, i even opened it back up to ensure everything was sitting correctly. Over the course of the night and day it has been fluctuating between the 5-10% battery, seeming to go on forever no matter what I do to drain the battery. I think i am going to attempt to keep it draining, and then eventually when it dies recharge it and go from there. If it still is acting weird then ill probably send it back. If u think of any other tips while i still have it let me know!
댓글 달기
귀하의 답변을 추가하세요
Ck Perrins 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 54
