주요 콘텐츠로 건너뛰기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 질문 전체 보기
My ps4 doesn't turn on and has a solid blue light. What can I do?
My PS4 suddenly stopped working when I tried to turn it on. None of the buttons on the console work so I can’’t even eject the disc. I have tried unplugging it multiple times and leaving it unplugged for weeks in a row. Can you help me please?
Thanks so much!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Since you have tried unplugging the device lets try other options. If possible, try replacing the power cable with one from a any other PS4 or PS3 and see if the issue persists when turning the console on. Just to make it sure that your power cable is ok.
See if the hard drive is seated properly and isn't damaged to fix the blue light of death
  1. Turn off your PS4 completely by holding the power button for at least 7 seconds
  2. Once the power indicator has completely shut off, remove the power cable, then all the other cables from your PS4
  3. Slide off the hard disk drive bay cover and check if the internal hard drive is seated properly
  4. If possible, unscrew the one screw that is holding the hard drive in place and re-seat it back into its slot.
  5. Once you've checked or reseated the drive, put the hard drive bay cover back on, plug all the cables back in and see if the problem persists when turning the console on
  6. If possible, check whether the hard drive itself works by setting it into another PS4 and turning it on.
Please try this and get back with status….
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Have you had any luck fixing this? Mine is the same and I can't find answers
@jswain1809 please describe your issue.
댓글 달기
귀하의 답변을 추가하세요
Joe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 1,398
