Why is my LG X mach device get into a reboot loop.
The phone on turning on gets rebooted immediately in a continuous cycle.
좋은 질문 입니까?
좋은 질문 입니까?
It could be caused by many factors: from electronic damage, software issue or just cache error.
At first please try to clear cache:
Then you should be able to navigate on menu to clear/erase/wipe cache - manage that. If you’re not attached to your data I would also recommend a full system wipe in the same menu. Check the results.
Next thing would be to check if it’s not an software issue. You should gather more information about your current ROM version (should be visible in recovery mode) and try to re-install it (either via USB or from SD card).
If it will not help it can be that your motherboard is damaged.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 500
