주요 콘텐츠로 건너뛰기
Repair manuals and information for the Microsoft Surface book line of laptops.
205 질문 전체 보기
Why isn't my surface book clipboard not charging?
I just bought a surface book from ebay. I let it charge for a few hours while I went to class, when I came back it said Batter 1: 0% and not charging. I’ve tried everything, from resetting to repairing using the surface diagnostic tool. Nothing seems to work. I even tried manually charging the clipboard. But it just won’t charge. If I let the clipboard charge for an hour then it shows 88% and shuts down immediately after I unplug it. When I attach it back to the keyboard it says 88% not charging, 75% not charging, until it reaches 0. The keyboard charges fine, the only problem is with the clipboard.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
If you bought it second hand, go find the seller.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Issues with laptops not charging correctly are usually related to a bad battery, a damaged charging port, or a damaged charging cord. Have you tried exchanging the clipboard’s battery and/or charging cord? This may fix the issue.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It is so common problem, which needs to be solved and fixed. I faced it last month when I was preparing for my classes. I only finished my paper and lost it in a minute, it was the day before the deadline, so I run out of time and needed essay help. That is why I had to ask help from this https://www.aresearchguide.com/essay-hel... project, the paper was great and I got a good mark. But I had to pay money just because I faced this issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Hardy Man 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,395
