주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
When iPhone 5c is turned on no image, when pressed, it works~
Hi,
About a month ago I purchased some parts to rebuild my old iPhone 5c, it had all the necessary parts except for the battery and the logic board, today I have finally received the last important piece, the battery, though when I was reassembling the phone the image on the screen suddenly disappeared like it burnt out. I tried several times reconnecting the screen but any attempt to use the phone rendered it turn the backlight on. However, after some “research” I was already thinking that maybe I somehow shorted out the logic board and that’s why everything was working fine except for the screen. At some point I was already thinking about reassembling the phone just to throw it away afterwards, but instead i pressed the screen and the image reappeared again and I was able to use touch screen except I had to press the higher part (well, where the flex cables are) of the screen in order to keep the image intact.
I don’t know what to do, Do you think that the problem is in the LCD itself or the problem is in the logic board?
Please I need some advice)
thanks in advance
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
its either poorly connected screen to logic board(try reseating the connectors) or a bad screen, I wouldn't have thought it was anything worse than this.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Ali Sadykov 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 23
