Asus ET2232I Not Powering On
I have an Asus LITEON WN6607AH-AD all in one PC. It is different from the one that I had to choose in the picture to the right, since IFixIt only had an option for something similar. I received it from a neighbor, and it doesn’t power on. I’ve managed to take it apart and do some diagnostics. I’ve tried pretty much everything I could think of, but it won’t boot. I think it might have something to do with a fried motherboard, which is a ET2232I Rev 1.2 board. I’ve looked online for replacement board, but it would be very expensive ($100+). If y’all have any ideas on what it could be or if you’ve had this problem before, then I would greatly appreciate your response. I’ve attached 2 pictures of the motherboard in case that would help.
Here is a list of the things I tried:
- Installing a ram stick (already has internal memory)
- Removing unnecessary cables from the motherboard
- Removed CMOS battery
- Tried 2 power cables
좋은 질문 입니까?
You don't mention what diagnostics you tried.
Have you checked the power supply, for example? Is it outputting 19VDC?
mike 의
Sorry. I have 2 different power supplies and I know for a fact they both work fine. I forgot to mention that the computer on the side I had to choose is different from the one I'm working on. IFixIt didn't have an option for my model. I'll try to add more info.
Petabyte Studios 의
Still can't get it to do anything...
Petabyte Studios 의
So it is completely dead?
No lights,
no fans spinning,
hard drive does not spin,
no beep codes sounding,
BIOS can not be loaded,
etc.?
mike 의
It shows no signs of power. Not even a light.
Petabyte Studios 의
9에 댓글 더 나타내기
