How do I hard reset a iview touch screen laptop
How do I hard reset my iview touch screen laptop
좋은 질문 입니까?
좋은 질문 입니까?
Iview has a number of Laptops versus Tablets, especially in the Maximus model. They are Notorious for this inability to power on issue. Especially if they have sat idol with the charger plugged in. I have a Maximus II and get this all the time. The following is what I do when I find my laptop will not power up after inactivity.
I unplug all peripherals ie, external cd rom drives, anything USB being charged and the like. I then push the power button while simultaneously holding in the volume up button. This does not always work the first time. I try it again but use the volume down button and if that fails I go back to option A. Just about the time I am ready to throw this item under the next oncoming semi truck I try option A very carefully ensuring I am holding the correct buttons simultaneously by sight.
This works everytime. Why? I usually find that I have either held down the keyboard lock button thinking it is the power button because they are right next to each other. Or I have been using the volume down button. It is also known that these “Laptops” need the option A tried a number of times before the power cycle kicks in. Why? If I knew that I would be working for Iview. Now before running over and finding my method doesn't work on Your laptop, and you want to burn me at the stake keep in mind that this is My Experience on My Maximus II and I only present this as a option to help.
Good luck all and I am stepping out to pollute the air and relax a bit.
해당 답변은 도움이 되었습니까?
i did that it didnt help
Omg thank you so much!!!
It worked! Thanks!
I've picked up a few storage units and have a few Views is there a way to completely wipe away all info and basically start over ( factory reset)
Click on START menu and click on Settings.
Select UPDATE and SECURITY on the bottom of list.
Then click on RECOVERY.
Select RESET THIS PC at the top of screen.
Choose REMOVE EVERYTHING Removes all of your personal files, apps and settings.
Check out the thread below and see if it works.
해당 답변은 도움이 되었습니까?
It’s now easy to reset your iview maximus touch screen laptop. I have posted a new topic in this regard. Here you can get the easy solution in step by step guide. Thanks
해당 답변은 도움이 되었습니까?
How can I reset my password for my view
해당 답변은 도움이 되었습니까?
Do you have a laptop or a tablet?
Reset my iview factory reset
해당 답변은 도움이 되었습니까?
Reset my iview to factory reset
24 시간 전: 3
7일 전: 11
30일 전: 96
전체 시간: 9,134
댓글 2개
It is a Tablet isn't it? Not a laptop computer.
mike 의
@mike no its a 3 in one laptop it just bends 360 degrees and is touchscreen
Lachrystol Smith 의
