주요 콘텐츠로 건너뛰기
HP Laptops designed for home and home office use.
677 질문 전체 보기
HP pavilion x360 15 CroXXX phantom ethernet connection
My laptop doesn’t even have an ethernet port and its showing an ethernet connection. It has been causing problems so I need this gone. Anyone have this issue before and know how to fix it?
Update (05/16/2019)
Here are the devices that show in device manager
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Hi @connor2003
How are you?
some things you can try.....
updating the computer BIOS,
what do you see in device manager on network adapters?
의 답변
I posted an update, please check it out.
의 답변
are you able to uninstall the Realtek usb gbe family controller from device manager?
if you are not using it, consider removing the drivers by checking it when you remove the device from device manager.
의 답변
@connor2003 all of it looks like wireless connections, not ethernet. What model is your computer?
의 답변
Hp x360 convertible 15-cr0037wm
의 답변
의견 추가하세요
2개의 답변
가장 유용한 답변
I see a VPN device driver installed. Uninstalling the vpn software should fix the problem.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Disabling it is the farthest I can go (still didn't fix it) Removing it would require entirely reinstall my vpn software.
의 답변
You can go into control panel then go network and sharing Center then go to network adapter's and see what it's called when you right click the ethernet adapter and go into properties
의 답변
의견 추가하세요
was this always a problem or is this something recent if so i would try using recovery setting to go back to a restore point if you are using windows 10 use the search bar and type recovery then open system restore follow the prompts and choose a date and time as far back as you can this should reset the setting back this will not effect your files
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Connor 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 96
