The dishwasher doesn’t take water
The dishwasher freezes and does not take water for washing, why? The model of dishwasher is the following:
좋은 질문 입니까?
좋은 질문 입니까?
Cause 1
Water Inlet Valve
The water inlet valve opens to allow water to enter the dishwasher. If the water valve is clogged or defective, water will not flow into the dishwasher. Water inlet valves are not repairable—if the valve is defective, you must replace it.
Cause 2
Water Supply Problem
Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. If the water inlet valve is clogged with sediments, the dishwasher won’t fill properly. Before working on the water line, first shut off the water supply. Inspect the valve to determine if is clogged. In addition, check the water pressure to the valve. The water inlet valve requires at least 20 psi to function properly.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 1
30일 전: 27
전체 시간: 1,337
