주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Phone cannot determine percentage/shutdowns(Changed the battery twice)
I have replaced the battery in my iPhone SE with two new batteries, both unable to work out how much charge there is (sometimes stays at 1% and changes when I plug/unplug the charger) The first battery I used made the phone restart (even while charging) every 3 mins or so, the battery I’m currently using is staying around 58% and is telling me to service in battery health. Both batteries were from eBay and I’ve tried basic troubleshooting like a software reset, updates and checking that the connectors are pressed in properly.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Do a thorough visual inspection, preferably with magnification, of the area surrounding the battery connector. There are several tiny SMD components just above the connector. Of particular importance is FL2400, hghlighted in red. If it is missing (which can happen when you pry the connector off), then the battery state does not get communicated to the CPU and this can also cause charging issues and fluctuating readings.
This can be repaired via a micro-soldering repair.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Thanks, I will open up the phone and take a look.
댓글 달기
귀하의 답변을 추가하세요
Aaweso_me 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 65
