주요 콘텐츠로 건너뛰기
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
154 질문 전체 보기
Car won't stay running.
Brand new fuel pump. Only starts with starting fluid. Idles then shuts off. Press throttle immediately stalls. Service engine light on.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Sounds like it’s not getting enough fuel. Could be a blocked fuel filter, EGR valve, mass airflow sensor, bad coil. Could be lots of things. Try pulling any stored codes via a diagnostics tool. Any codes should shed some light.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The mass airflow sensor located at or near the induction box. Try disconnecting it and start it. It should run and stay running, but will run rough. If this happens it maybe a mass air flow sensor.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Razors Nation 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 12
전체 시간: 1,179
