How do you expose the lens/sensor to blow dust off?
I can open the case but how do you get the lens/sensor exposed to blow the dust off the lens and/or sensor?
좋은 질문입니까?
좋은 질문입니까?
You have to remove the lens assembly from the camera then open it to reach the sensor.
이 답변이 도움이 되었나요?
Thanks for the reply, but how do you remove the lens assembly and open it? Is there a procedure/exploded view? from Canon?
Canon service manuals are pretty hard to find but maybe oldturkey03 could check if he can find it ?
The only tutorial I can find is how to replace a bad LCD panel on a A590:
Se if this will help to get the lens cover off Canon PowerShot A590 IS Flash Assembly Replacement
이 답변이 도움이 되었나요?
Thanks, but this procedure does not continue to lens assembly removal/opening. Is there a continuing procedure available?
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 1,329
