주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1208 질문 전체 보기
Microphone, earpiece speaker, rear camera and a boot loop
A couple days ago my personal iphone 7 plus started malfunctioning severely.
First, the mic stopped working during a phone call, then the earpiece speaker refused to work. Tried powering it off, and doing a hard reset. The result was a boot-looping device for the next 30 minutes. It finally stopped boot looping, and i was returned to my home screen. I afterwards discovered that the rear camera no longer actually takes pictures. I can see images on the screen, but pressing the button results in no saved picture no matter what i do. The front (selfie camera) does actually take pictures and saves them, but you have to hold still for about 15 seconds after pressing the button.
Has anyone seen this before? If so is there a known issue? Is there a part i can replace that can remedy this? i have not tried a restore yet, that is my next step, but not until i get a new phone. Until then i am left with a device that cannot make or receive phone calls.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 2개
선택된 해법
All these symptoms point to iPhone 7 audio IC disease. Check to see if voice memo works. If not you will need to run a jumper under the audio chip.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
oh no. hopefully that isn't the case. will report back when ive had a chance to try other remedies
의견 추가하세요
가장 유용한 답변
First remove the front camera flex and check,hope you got all answer after doing that.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
thank you i will give that a shot
의견 추가하세요
귀하의 답변을 추가하십시오
Chris k 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 61
