5 pink vertical stripes, new video card and screen tried,
Hi I have replaced both the video card [brand new] and the screen but the problem has not gone,
Is it the logic board that needs to be replaced? Any way I can confirm this? Thank you
Update (05/21/2019)
Hi Dan,
Actually to be more accurate, after repeated rebooting the the iMac started working normally,
I then did the hardware test and all passed but now after almost 3 weeks it has stopped working with the same typical 5 pink vertical lines as before,
I have not connected it to an external monitor. Do I need a special cable for this, Thanks again!
좋은 질문 입니까?
댓글 2개
Can you post a few pics so we can see what you see on the screen.
Also have you tried an external monitor to see if the effect is on it as well.
Dan 의
All you need is a Mini DisplayPort cable to either a VGA or HDMI connection needed on your monitor. As example Mini DisplayPort to VGA Adapter
Dan 의
