다양한 TV 브랜드 및 스타일 안내서 및 지원.
4441 질문 전체 보기
Philips Lcd Tv won’t turn on (stuck rebooting)
Hello, so when I plug my lcd tv it just turns on the red led, flashes the backlight for half a second and then reboots. If I don’t unplug it it keeps going and going. Is there a way I can fix it?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
@tomst what is the complete model number for your tv?
의 답변
@oldturkey03 it’s 26PF5321/77
의 답변
의견 추가하세요
아이폰 배터리 수리 키트
Only $29.99
Buy Now
아이폰 배터리 수리 키트
Only $29.99
Buy Now
1개의 답변
가장 유용한 답변
@tomst what I get out of this is that your TV never completes the booting up and goes into a boot loop. That sounds like an issue with the main board or the firmware. https://philips-tvconsumercare.kxondeman... Start by removing every input from your set and unplug it. Then hold the power button down for a minute or two. Plug the set back in and connect one input source. See if that made a difference. If not remove the back of your TV and check the boards and the interconnect cables. Post some images of what you see with your question. Adding images to an existing question
해당 답변은 도움이 되었습니까?
점수 2
댓글:
@oldturkey03 i tried what you said and it is still the same. I uploaded a picture of the inside. There is nothing wrong I can see about it but maybe you see something I don’t.
의 답변
@tomst can you check the Philips website to see if there is a firmware update for your TV? They do have the instruction on how to update. Just to make sure that this is not a firmware situation.
의 답변
@oldturkey03 i don’t think I can update the firmware since it is an old model, it doesn’t even have usb. It always worked fine until like 5 years ago.
의 답변
Okay let me look at the schematic and see which way we are going to approach this. Do you have a multimeter?
의 답변
Thank you so much for your help. Yes I have a multimeter.
의 답변
7에 댓글 더 나타내기
의견 추가하세요
귀하의 답변을 추가하십시오
Tom 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 87
전체 시간: 87
