Repair guides and support for Panasonic's Viera line of televisions.
207 질문 전체 보기
Panasonic TV Won’t turn on (tx-48ax630b)
Hi
i have an issue where the tv won’t start. It’s 4.5yrs old and the details/ fault are below. Any ideas welcome
Panasonic tx-48ax630b. When turning on the green light flashes 9 times (slightly longer long one on the 9th), then 9 again, then a single slow red flash. Screen try’s to light up but then goes off.
Tried the reset methods but no luck.
.... oh, and the power button has been a bit loose now for a while but still worked and clicks.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
아이폰 배터리 수리 키트
Only $29.99
Buy Now
아이폰 배터리 수리 키트
Only $29.99
Buy Now
1개의 답변
가장 유용한 답변
James Algar 9 blinks on your model is for a SOUND_SOS and the most likely culprit is your A-board. The A-board is the main board. remove the back from your TV and check that board for obvious damage. you can always post good pictures of your boards with your question. That way we can see what you see. Adding images to an existing question
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
James Algar 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 33
전체 시간: 33
