주요 콘텐츠로 건너뛰기
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
44 질문 전체 보기
Replacement digitiser - home button not working
I’ve just replaced a friends digitizer on iPad 5, and the home button doesn’t work. I tried checking the connections and all seem fine. Any ideas please?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Crikey I might need it - thanks for your help!
의견 추가하세요
답변 1개
선택된 해법
Did you use an iPad Air digitizer with pre-installed home button? While the digitizer works on both Air and 5th gen, home button is not interchangeable as they use different protocols.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Thank you - that’s interesting - it did say iPad Air / iPad 5 so probably. The previous home button was damaged by the glass, so I assume a new home button is required? I’m worried if I try to take the digitizer off again, it’ll damage the new one though?
@jg0254 That explains it, you need to buy a new iPad 5 home button, you have no choice but to take the digitizer off again :(
Do it with care to not break the glass, good luck.
의견 추가하세요
귀하의 답변을 추가하십시오
Jake 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 34
