주요 콘텐츠로 건너뛰기
Model Number: U405D-S2902, Processor: AMD Turion™ X2 Dual-Core Mobile Processor RM-72,
3 질문 전체 보기
Backlight flickers whenever display is at certain angles
First off, my laptop is actually a U505, not 405. There’s no listing for it, so I had to choose this.
As my question says, the backlight will occasionally die whenever the display’s at a certain angle. It also will sometimes cut out and the laptop has to be restarted to get it back.
The hinges are loose, and I can’t seem to find the original screws.
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
It is likely the power wires going to the backlight. The position of the hinge will vary the stress on these wires. Take off the shroud around the screen and look at the wires going to the backlight. The wires are usually white & pink. These wires carry high voltage so be sure to remove the battery pack prior to touching them.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Jessica Parnelli Fawkes 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 34
