주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2015년 5월 업데이트에는 5 세대 Intel Core i5 및 i7 프로세서가 성능과 배터리 수명을 약간 향상시켰습니다.
623 질문 전체 보기
Pulled lcd connector pad
Hey,
i had had a water damage Macbook come in for repair. I took the LCD Connector off because I noticed it was burnt on the right side of the logic board.
anyways, I pulled the connector off and noticed a pad was gone. I looked at the trace for it and it looks like the last pin is on the same circuit. Can some chime in to tell me if I could solder the pin over to that one? And possibly provide a schematic of this connector so I know what it does
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Actually, it looks like the pad is not connected to anything, at least not on the surface. Perhaps that’s just because the picture isn’t zoomed in enough.
As for the schematic, you have to provide the logic board model number otherwise we’re just guessing.
EDIT
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
Sorry I desoldered the connector and seen the pad was pulled. I’m curious to know if that pad is ground or not needed for anything
This logic board is for MacBook Air 13” early 2015
I meant to say "pad" and not "connector" (see edit above).
What is the logic board model number (820-XXXX-X), you will see it silk screened on the pcb.
I updated my question with the board pictures . I couldn’t see 820 anywhere on the board
It's pin 2, NC as I suspected.
댓글 달기
귀하의 답변을 추가하세요
Daniel Ringuette 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 81
