Technics SA-5550 anti-shock timing circuit
1976 Technics SA-5550 stereo receiver was working perfectly. But then I used air blaster on it to clear out dust, and the the “anti-shock timing circuit” stopped functioning. The literature on this describes the anti-shock timing circuit as “helps eliminate annoying thumps in the speaker after turn-on by delaying turn-on of the speaker terminals”. What is the remedy? Is it possible dust got lodged in the circuit?
좋은 질문 입니까?
댓글 3개
Sounds odd. Are you sure you didn't bump or drop something inside?
mike 의
I'm quite sure I didn't bump or drop something inside. I only used the dust blaster.
I should add that when powered on, the lighting and the radio signal strength meter are still working.
mchlgrblsk 의
DO u still have the receiver I am looking for one thx crickern @ gmail com
Fernando Flores 의
