주요 콘텐츠로 건너뛰기
첫 번째 iPhone 모델, Model A1203은 4, 8, 또는 16GB 용량과 알루미늄 뒷면을 가지고 있습니다. 수리를 하려면 상당한 양의 비집기와 납땜을 요구할 수 있습니다.
224 질문 전체 보기
질문 마감됨
Force restore will not work; iTunes does not "see" phone
Following the directions on iFixit I can get my 1st Gen iPhone to display the connect to iTunes graphic, but when I connect it to my Mac iTunes does not "see" the iPhone, so I can't restore it. I tried two different USB ports and two different USB cables to be sure the issue wasn't the connection (and anyway both ports and cables work fine with my iPad).
Suggestions?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Have you tried plugging it into a wall? Does it charge? If it doesn't your dock connector may be bad. If that is not the case I wouldn't know.
Hope it helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
It charges fine.
Actually, having said that it doesn't appear to be charging consistently.. loose connection? Is that something I can replace, or is it on the logic board?
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 895
