주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1479 질문 전체 보기
sim not supported for verizon on verizon network
I have installed an iPhone 6 Plus Logic Board / Verizon / 64 GB to replace my iphone 6 plus logic board verizon. When I installed my Verizon Sim Card, I get the message Sim not supported:
the sim card that you currently have installed in this iphone is from a carrier that is not supported under the activiation policy that is currently assigned by the activation server.
If the Iphone 6 plus logic board is not verizon how to I identify what carrier it is?
i have checked the IMEI number, it is compatible with verizon.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
If it was me I would get a GSX report for your phone they are only a couple of dollars. If not I would find the country of sale through 3Utools and then input the imei number into all those carrier databases. The only phone I have encountered that message on turned out to be carrier locked which is shared on most networks. Good luck.
의견 추가하세요
답변 2개
선택된 해법
Apparently, the new logic board you installed wasn’t a Verizon board. You need to contact the seller as they apparently shipped you the wrong board.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
The logic board is locked to AT&T. So i must unlocked the phone using the At&T site, or go to an illegal site and pay 50-100 dollar to AT&T unlocked
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
DAVID NGUYEN HANG, demona 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 13
30일 전: 61
전체 시간: 841
