주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.6 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.2 GHz). 2013년 2월 13일에 출시되었습니다.
121 질문 전체 보기
New Battery Is Charging & Recognized, Won't Run on Battery
Just replaced the battery in the MacBook Pro 13” with a new one from iFixIt. The battery shows up at 78% and is charging, I’m watching the mAh increase. The LED on the charger shows orange, as in charging. If I disconnect the power supply the computer won’t run on the battery alone, it must be plugged in, even though it has a charge. Any ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 4개
Lets get a better idea on what's happening. Install this gem of an App CoconutBattery Take a snapshot of the main window and post it here for us to see 기존 질문에 이미지 추가하기
Thanks Dan, I uploaded that.
Well the battery does appear to be in good condition as you implied.
So that part of the circuit is working so if you now pulled the MagSafe connection he system would just shutdown on its own in a few seconds. Is that correct?
@danj Right, if you pull the MagSafe it powers off immediately. Battery has charged all the way up now thouhg.
댓글 달기
답변 1개
가장 유용한 답변
Sadly, I think the switching logic which control the power source from the battery to the logic board is not working.
It’s going to take someone with deep circuit diagnosis and access to the needed schematics and replacement parts.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Greg Dietrich 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 100
