The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Are you sure the volume is turned up? When was the last time the sound was working? Did you make any changes to the 2DS before the sound stopped working? Did the 2DS get damaged or get wet before it stopped working. Can you hear the sound if you plug in some headphones?
Sorry for the delayed response, but I figured it out...I neglected to mention that I did go inside it to replace the tiny joystick, and I inadvertently hit the volume switch from the inside. But thank you for taking the time to respond.
Joshua Freeman 의
