주요 콘텐츠로 건너뛰기
Known as the E39 , the 4th generation of the BMW 5 Series mid size sedan.
13 질문 전체 보기
Why is my car giving an excessive dicharge error?
I have a 2005 BMW 5-Series E60 that is draining the battery when it sits for days without use.
I have a relatively new battery.
I have disconnected the negative terminal of the battery, and I am pulling 3.3amps of current!
I have systematically removed every fuse in the trunk fuse panel, and the panel behind the glove box while monitoring the current. No change to the current draw with any fuse.
I have “re-registered” the battery using a code reader, and cleared all other errors.
I continue to get an “excessive discharge” error.
Are there any other (unfused) points of current draw I should be looking for?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Try disconnecting the IBS (Intelligent Battery Sensor)
Here is a YouTube video Explaining the procedure.
https://www.google.com/url?sa=t&source=w...
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Brilliant! Worked like a champ, and I've been able to keep all codes cleared! Many thanks!
Glad that I could help.
Mike
댓글 달기
귀하의 답변을 추가하세요
Thomas Duffy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 22
전체 시간: 107
