주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
MacBook, MacBook Pro 및 MacBook Air에 사용되는 AC 전원 어댑터. 잡아당길 때 안전하게 분리되는 자가-정렬 자성 커넥터를 사용합니다. 1 세대 (2006-2012) MagSafe 충전기는 약간 두꺼운 L 자형 커넥터가 있습니다. 45 W, 60 W 및 85 W 버전으로 제공됩니다.
76 질문 전체 보기
Idle voltage at 17 Volt instead of 6.8 V after changing MagSafe cable
I replaced my broken MagSafe 1 cable with a replacement cable and get some weird idle voltages:
After desoldering the broken cable from the two pins on the PCB, I checked the idle voltage. My multimeter gave me a reading of 6.84 V which is in accordance to the ifixit guide and Wikipedia.
However, after attaching/soldering the replacement cable to the two PCB pins, I get an idle voltage of around 17 V. As far as I understand, this is the regular charging voltage at load, but not at idle. Since I ordered two of these replacement cables, I tried the other one, but got the same result: ca. 17 V at idle.
My MacBook Pro is charging with the repaired cable, but does not light up the green LED inside the magnetic connector when fully charged. I assume that this is due to the power supply not reducing the voltage to the required 6.8 V at idle.
Does anyone know how to fix the idle voltage and get proper charging behaviour?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
답변 1개
가장 유용한 답변
I personally don’t recommend trying the fix the charger.
Theres a bit more going on here than meets the eye! The MagSafe connector has a small circuit which ID’s the wattage of the charger so the cable you got is likely not the correct value. Here’s a bit more Teardown and exploration of Apple's Magsafe connector
These cables are very suspect! As Apple never offered any parts for the charger and these cables are either recovered from the cloned MagSafe chargers or may not even have the needed circuit which could put your system at risk of damage! OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
Don’t get me wrong here Apple’s MagSafe charger design should have had a removable cable from the get go! Like what we now have with the USB-C charger design. But, even its design is flawed! As what made the MagSafe design so good was the break-away connection on the system which is now missing on the USB-C systems.
So Apple went from bad to bad! Maybe the next systems fix this failure.
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
귀하의 답변을 추가하십시오
Albert Emil 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 63
