Why Can't I upgrade my 2010 MacBook Pro to 16gb?
I have a mid 2010 13” MacBook Pro. 2.4GHz Core 2 Duo, running High Sierra 10.13.6.
- Boot Rom 66.0.0.0.0
- SMC 1.62f7
I recently purchased a RAM upgrade 8 GB x2 SO-DIMMs to get to 16 GB (1066 MHz).
But when I install them my Mac won’t start up. If I use the stock 2 GB memory it starts just fine.
I have tried every combination of sticks and slots, but it will only work at the max of 10 GB. Please help.
Update (06/18/2019)
Model Identifier is MacBookPro7,1 the other numbers are in the original post.
좋은 질문 입니까?
댓글 4개
Your systems specs 13" MacBook Pro 2.4 GHz Core 2 Duo (Mid-2010)
Dan 의
Curious if you got anywhere with this. I have basically the same issues (Boot ROM 67.0.0.0.0 is the only difference), and I would love to figure out how to get the EFI update to work.
2x4GB DIMMs have worked fine for years. 2x8GB doesn’t. I may try to mix and see if I can get to 12GB.
Steve 의
12GB worked, but I could never get 2x8GB working. I bought chips from a different vendor and those worked perfectly. *shrug*
Steve 의
+1 to Steve. See comment on guide:
MacBook Pro 13" Unibody Mid 2010 RAM Replacement
bprima 의
