주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
ERROR 29 when updating ios with APN 616-0435
I have 3gs old bootrom, and somebody changed battery before i bought it, i got error 29 on update to 4.1 to 4.3.1 or 4.3.3,
Than i put the APN 616-0435 battery and again the same problem, i dont know what was old APN on the battery, can you please help me, anybody, i have tryed everything.
When i use redsnow and kick it from restore it restarts every 2-3 minutes, doesnt recharge when connected to usb port, only when the phone is off and connected to a wall charger
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
i'd purchase another battery from another dealer and see what happens. this IS a common problem with batteries and 3gs iphone. check out the feedback on wherever you purchase from first to make sure that it's likely to be a good replacement part.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thank you for the answer, but i can't be shure anything any more, i can't afford throwing away any more money on batteries, if i only knew which battery was inside originaly...
댓글 달기
just downgrade your 3gs and everything will go back to normal (i had exactely the same issue - old bootrom, 3gs, APN 616-0435 and 4.3.3
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Teo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,558
