주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1199 질문 전체 보기
iPhone X diagnosis device won't turn on
Two weeks ago my IphoneX just died while I was charging it. I did the reboot steps but didn't work. I connected it to the itunes but it still did not work. So, I went to the apple service center to get my phone checked. They said that my device won't turn on and the reason behind it is because of the logic board or the motherboard of my iPhone is damaged. AND they can't do anything about it or fix it. All they can advice to me is to get a new one or a replacement phone which costs about $780 because my warranty is expired. My phone is already a year and a half old. I MEANNN come on. I’m so frustrated right now. What should I do?? My phone was working really well before the incident.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
Please do tell me or share anything if you have kind of the same experience.
Will happen from time to time, Look at local facebook marketplace for cheap repairs, Good thing about todays time is a lot of people to repair phones and help you. You're device is already out of warranty so wont have to worry about on that side.
Thank you for your comments. You guys are very helpful.
댓글 달기
답변 1개
가장 유용한 답변
The problem with cheap places is that they are cheap for a reason, look for someone good and reputable that is able to repair the phone for u...
A bad cable or bad charger can cause what ur describing, look for someone reputable that is good at their job and tell them everything exactly what happened to the phone, if it was dropped etc if it was charged on a dodgy charger etc and they should be able to fix it for u. Take it somewhere that doesn't specialise on these kinds of things just because it's cheap then ur likely to loose ur chances of being able to fix it and places that can may charge u more because it's been tampered with
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I agree with C here..."cheap repairs" and "iPhone X" don't go together. It is an extremely complex device to repair and cheap places will probably kill your device more than anything else.
댓글 달기
귀하의 답변을 추가하세요
Gee Lyn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 2,458
