X keeps restarting after new charging flex.
Phone keeps restarting after around 3 minutes. Customer came in for charging port replacement. All screws in right place, no long screw damage.
It has had the following to rule out:
Battery and 3 replacement ports. Each flex cable was unplugged one by one to troubleshoot, even with the following unplugged it occurs: Screen Flex (Both), Face ID/Front Cam Flex (All 3), Antenna Flex (Wifi), Lower Antenna, Power Button Flex/Flash & Volume Button Flex & Charging Flex.
I have tried a replacement screen and still occurs. I have checked all the FPC under microscope and very clean and tidy. It cannot be the port surely as it occurs even when not plugged in.
좋은 질문 입니까?
댓글 14개
Did you find out what the issue was? I did the same repair with the same results.
Repair-IT 의
I will be grateful for info how did you fixed that issue. Thanks
Lerby 의
How did you fix it?
Maryam 의
In my case the new charging interface was a problem. When I returned to original part with faulty microphone the problem didn’t returned.
Lerby 의
im facing this same issue now on iphone X keeps restarting after charging flex replacement . any solutions please ?
arshad 의
댓글 9개 더보기
