주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Why won’t the screws inside the phone unscrew?
I have been trying to unscrew the screws that lead to where you can disconnect and reinstall the battery. I have tried my PH000 screwdriver and PH00 screwdriver but neither have worked. I bought the screwdrivers from a tzumi Pro Glass phone repair kit.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Problem there is that you have a small screw mounted on a bigger screw below. Probably someone already worked on the phone before you and didn’t set firmly the big screw below, thus when you now try to unscrew the small one, both turn together. Try doing the other way around, screw it tightly and then try unscrewing again. Or if that doesn’t work you’ll have to find a way to pry away the cable cover. Make sure battery is fully drained first and be careful, chances to short the battery are there.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
I tried screwing it tightly and unscrewing it but it wouldn’t unscrew. The phone hasn’t been charged in three days and I can’t charge it past 1% so it’s dead
@s3k Then prying is all it's left..with some care and tools it can be done..not the ideal solution but it seems there's no alternative. If battery is well dead snapping the cable with insulated scissors may help by adding some working space. Beware these are not in any way recommended nor recommendable procedures, so be ready for possible consequences. The only safe action here would be to dispose of the phone properly and buy a new one.
댓글 달기
귀하의 답변을 추가하세요
Kayla Sky 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 182
