주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
591 질문 전체 보기
Swap the board for a 2012?
Hi, I have a mid 2010 MacBook Pro 15 inch with the 2.8GHz i7, and I was wondering if I could swap the board for a 2012 15 inch unibody board. The performance in mine is fine for me, but I really want the 2012 board because it supports 16GB of ram. Thanks (Also I know I would have to buy a new battery and im willing to do that as mine only lasts like 40 minutes anyways)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Beside the battery that has a different connector the only part not matching is the WiFi/bluetooth flat cable that is slightly misaligned and with different lenght. However it’s an inexpensive and easy to replace part that won’t make much of a difference in the overall upgrading costs.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Is the display connector the same? In some A1278s I've seen some connectors that have the rectangle base style and the newer style ones with the different slightly bent curved flaps.
@benjamen50 You're right, with A1278 a swap wouldn't be possible because of different LVDS cable to start with, but also Wifi/Bt and camera cables would be a no-go. With 2010 i5/i7 in A1286 and later quadcores everything is basically the same..there is only a very tiny difference in LVDS connector width that can be fixed with just a touch of sand paper beside the flat cable I mentioned.
댓글 달기
귀하의 답변을 추가하세요
Brandon Ingram 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 36
