주요 콘텐츠로 건너뛰기
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
159 질문 전체 보기
Drift on right joystick without visible fix
I’ve been trying to fix the drift on my Xbox One controller for a while, but nothing has seemed to work so far. Currently, the right joystick is consistently registering a left input while at center. This is a FULL left input, though, as I’ve gone into a game with this malfunction and it would make the camera in the game rotate left at full speed.
I have taken apart the controller already, and tried to replace the circular sensors that are held within the green portions of the joystick module on the motherboard. I’ve even turned on the controller with the sensors completely removed, and there is still a left input on the joystick.
I have a replacement module, but I’m unable to get the current one off since my soldering iron doesn’t seem to be hot enough to melt the contacts. Is it a lost cause? Should I just get a new controller?
UPDATE: I was able to replace the joystick module, but nothing had changed. There is still a full leftward input on the right joystick. The new module is working, as I’m able to see inputs from the joystick as I move it around, but only up, down, and press. So I’m guessing it has less to do with the actual module and something a bit deeper.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
You need another tool to remove the joysticks off a controller. As long as the solder when melting turns shiny / malleable then that means the soldering iron is hot enough but needs help with another tool mentioned below:
This is the tool you need it is called a “Solder Sucker”. Basically what this does is sucks the melted solder into the tool so that it helps you with having the pins under the object that you are de-soldering not to be soldered together with the pad on the board.
Here is a link to the aforementioned tool: https://www.amazon.com/Solder-Sucker-Des...
Filling the pins and pads with leaded solder will make this process easier. Simply add leaded solder to these pads, heat them up for about 5-10 seconds then use the solder sucker with the nozzle propped against the pad and press the button on the tool to have it suck up the melted solder.
You’ll need to do this a few times so that it gets rid most of it properly on all the joystick pads. Once that’s done you may need to use solder wick to remove excess / residue solder on the pads so that you can mount the replacement joystick in place and solder that one into it’s respective pads on the board.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Ah, thank you. I'll check this out.
Saw your update on your post. At this point this problem will need to be diagnosed at board-level.
The cause of the problem in this case would usually be one of the following either liquid damage or physical damage from dropping the controller on the board.
For what it's worth in terms of cost and time it may be time for another controller.
댓글 달기
귀하의 답변을 추가하세요
Bryan Christian 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 1,409
