메인 콘텐츠로 스킵하기
Apple의 MacBook Air 13" 2014년 4월 업데이트에는 참신한 듀얼-코어 i5 및 i7 프로세서와 더불어 배터리 성능을 약간 향상시켰습니다.
188 질문 전체 보기
Why is my MacBook Air crashing?
Hello!
I have an Early 2014 13” MacBook Air that sometimes crashes.
First of all, I wanna mention that the actual SSD isn’t the original one, but an Intel 660p and it’s connected into the SSD slot from the motherboard with a special adapter.
OK, So the problem is that sometimes the machine turns off, and then I have to disconnect the battery for some hours ( 3 - 5 even 10 to 12) to work. One time I wasn’t able to use it for about 3-4 days, same problem.
Before crashing, the backlight of the keyboard is flashing, turning on and off for several seconds.
Even the charger won’t work properly in that period of time, the indicator light won’t the right one, sometimes was green, even if the battery was at 30- 40 % of juice, or sometimes the color was only orange from the moment I connect, and the color won’t change from an normal green first to orange, if isn’t full.
Another thing that I think it’s not normal is that the processor is very hot, like 70’ - to 90 ‘ Celsius degree, even if the thermal paste was changed by myself.
I don’t know if the problem is the SSD, but sometimes when i started the MBA, when the problem was persisting , the “STOP” sign showed on the display (that cutted zero).
This has been returned by the MBA when it turned on (this post was made with the actual machine, ‘cuz now, somehow, it’s working)
Well, I wanna know is someone had this problem and how has been fixed.
Panic Report
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
가장 유용한 답변
Well you do have a few problems!
First do you still have your original Apple SSD? If you do lets put it in and tell us if any of your problems continue.
The crash report implies your System Management Computer (SMC) is encountering issues. I’m not sure if the source of this is related to the SSD or if you have other issues. If this is still an issue after putting back the original SSD then your logic board is encountering issues.
Did you have a liquid spill at one point? Also you talked about applying a fresh coat of thermal paste what did you use and are you sure you applied enough and not too much? Depending on what you applied it can create issues if it gets onto the SMT components on the chip carrier.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Florin Bogles 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 15
전체 시간: 15
