주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2191 질문 전체 보기
Why is sound/mictophone/vibrator not working?
I replaced my iphone 4s screen by my self.
When I was finished and checked the phone I found out that there was no sound coming out of it at all. No sound from either speaker.
(both cameras worked , bluetooth and wifi worked and celural antena worked)
I tested it by making and receiving a call and I found out that neither my microphone nor my vibrator was working.
I tried rebooting and hard reseting it but it didn’t work. That let me to believe it is a hardware problem.
I reopened the phone and made sure all the connectors where connected properly , and they were. (still all those things I mentioned didn’t work)
I probably damaged something during the repair.
What can I do ? Do I need to replace anything ?
By the way I filmed everything with another phone (quality is bad) , so any expert can briefly watch it and maybe tell me where I did wrong.
(https://www.youtube.com/watch?v=M7MqRjCG... )
Any answer is welcomed.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 5개:
Video says its unavailable
Check or change the charging flex...
I forgot to add that headphones don't work either .
Will they work if I change the charging flex ?
Try disconnecting the charging flex and see if u get headphones working, failing that plug in the charging port and disconnect the headphone flex it's the one connected to the volume buttons and see if u get sound out of the bottom :)
@c9679 Video is now online
Lol I am sooo sooo sorry that is too painful to watch I watched till u struggled to remove the battery and I just couldn't watch further... so sorry please do try disconnecting the headphone port flex and the other suggestions I recommended lol
댓글 달기
답변 1개
First thing I would swap is the charge port. As this controls all the functions you mentioned (minus the vibrate issue)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Nektarios 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 77
