주요 콘텐츠로 건너뛰기
Dryer does not display correct time for selector switch setting
We had a brief electrical outage when our dryer was working - I was actually in front of the dryer taking clothes out (on timed dry cycle ) and the dryer beeped, all the lights lit up and it powered off, then on. No dryer error codes were displayed. When it powered on, I noticed that the time on the display no longer corresponds to the setting on the selector switch. For instance, the timed dry setting used to be 12 minutes but now shows 3 dashes on the display. Other cycles are similarly affected. The small load setting also shows 3 dashes as does the towels setting. Any ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Try resetting it by unplugging it from the wall for ten minutes.
UPDATE
Your control board may be fried. Please give us your model number so we can locate the part needed.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thanks for the tip. I unplugged it for an hour, powered it up, no luck. Also tried running a load and tripping the breaker - dryer correctly showed a Power Fail code but still does not function correctly. Time for a service call.
댓글 달기
귀하의 답변을 추가하세요
Kirby Kroon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 39
