No display after LCD and Digitizer replacement
The owner put his iPad down and forgot it, then ran it over (yikes), spiderwebbing the glass across the whole device. The LCD did still work, but the removal process wasn’t kind to it and it got broken. Fast forward, I’m testing the new display unit and I get nothing but a backlight. The device still works underneath, I can unlock it and everything if I guess the right spots on the screen. I read some other threads on here and hooked the old display back in, I get lots of pretty lines, so is the LCD driver still intact?
I’ve checked and re-checked everything, but I can’t see anything horrifically out of place or disfigured.
Bad replacement unit or something fried on the logic board?
좋은 질문 입니까?
댓글 3개
Did u try the obvious of restarting it, pressing the home button and power button, etc??? Have u tested the replacement screen on another ipad
c9679 의
@c9679 Yeah, I restarted it. I also disconnected the battery, unplugged and plugged the display and digitizer back in, then reconnected the battery. I do not have another iPad to test the replacement on, this is the only one the company owns.
Paul Rigard 의
See if u can try another screen on it though sounds like the first one is damaged and the replacement may be faulty so that needs to be ruled out... :)
c9679 의
