주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
{A1706 / EMC 3071}—2017년 6월 출시, 이 MacBook Pro 13”는 Kaby Lake 프로세서 최대 3.5 GHz Core i7 및 Turbo Boost 최대 4.0 GHz 포함.
Why my touchbar have a purple tint around the icon?
이미지
I have an MBP 13" 2017 , which recently started showing a purple tint around the touch bar icons. It looks there is some sort of issue with it, as at times it just fades and flickers. Every function on the touch bar works as it is supposed to but there is some kind of issue with it.
I have tried booting in safe mode, resetting SMC, NVRAM but the issue is still there. Finally, after a few chats with Apple support, I completely wiped out and did a fresh install of the OS. And after everything, the issue is still there. So it looks like it is some sort of hardware related failure.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
Having the same issue on just 15 days old machine. I got 16 inch MacBook Pro on 6th January 2020 and experiencing the same issue now.
@Erick Bassan - Time to visit an Apple Store or authorized service center
댓글 달기
답변 1개
선택된 해법
I’m not very familiar with touchbar build, but I’d say you’re definitely right, looks like a hardware issue. Hard to tell if it ‘s the touchbar itself or some circuit feeding power/data to it. I’m afraid Apple would charge an arm and a leg to fix that. The other alternative would be find some independent lab into component level repairs but that’s not going to be very cheap either. It’s a bit alarming such a thing may happen on a less than 2 years old machine.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Bara Limbong 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 35
전체 시간: 997
