메인 컨텐츠로 가기
HP Laptops designed for home and home office use.
685 질문 전체 보기
HP Pavilion X360 cr00037wm bluetooth connetivity/quality issues
This is a (very annoying) problem I’ve had since I got this laptop. Almost every time I use bluetooth, it starts cutting in and out thn goes to really low sound quality and continues to cut out. Yes drivers are up to date yes i’ve tried unpairing and reconnecting still won’t fix it. Should I just buy an external USB receiver? (which I won’t do unless I absolutely need to). Yes the speakers on my laptop are fine but I like being able to use my JBL flip 4 and not have the audio quality held back.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
코멘트 추가
안드로이드 수리 키트
새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
지금 장보기
안드로이드 수리 키트
지금 장보기
1개의 답변
As with all driver problems it must first be COMPLETELY uninstalled. Not just the standard “uninstall”.
Use one of the very good freeware uninstallers that scour the registry, etc., as well.
Reboot and then re-install.
Let me know how it goes. If it doesn’t work probably a hardware issue.
이 답글이 도움이 되었나요?
점수 0
댓글:
I have done a complete reinstall before, fixed it for a (very) short time. Forgot to mention that it also randomly disconnects Bluetooth devices, yet it works flawlessly with my Xbox controller.
의 답변
In the past I've had problems with different versions.
Have you tried this site for help:
https://www.bluetoothandusb3.com/
의 답변
코멘트 추가
답변 추가
Connor 이(가) 영원히 고마워 할 것입니다.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 23
