My iPad keeps powering off after having to change the cracked screen.
iPad 6thgeneration keeps turning off after having the screen replaced when I dropped it and the screen cracked. It works intermittently. Someone mentioned it may be a problem with the digitizer. Can this be fixed?
좋은 질문 입니까?
댓글 2개
Are you using a flip cover that automatically locks / switches off the screen when the screen is covered?
If yes it's most likely going to be a damaged home button cable causing the problem as there is a sensor on there to sense the magnet in the smart cover.
Ben 의
Yes, it worked fine before having the screen replaced, so I guess I’ll bring it back to the tech again. He changed the screen twice so far.
R Keating 의
