주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2026 질문 전체 보기
How to hard reset iPhone 6s and also how to fix mushy home button
Hey there I need to either backup or hard reset my phone but it is not recongised by iTunes and cannot be hard reset as the home button is mushy? Does anyone have a fix for these issues?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
PC 노트북 배터리
큰 전력 향상을 위한 손쉬운 수리.
지금 장보기
PC 노트북 배터리
큰 전력 향상을 위한 손쉬운 수리.
지금 장보기
2개의 답변
선택된 해법
Basically, I just swapped the replacement home button bracket for an OEM one and then I could follow Reflectio’s steps so that I could hard reset the phone. In the end I didn’t need to hard reset the phone I just found the original owner’s Instagram from the notifications on the phone (after putting in a sim card so that I could use mobile data as internet.) They were happy to give me the password. Thanks for the help!
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
가장 유용한 답변
Removing the passcode is easy…you don’t need to “know a guy” to do it. But doing this will delete any data you have on the phone.
There is no way to get the data off the phone unless you can open it, unlock it and have it recognized by Windows/MacOs and then subsequently through iTunes or any other management software (such as 3uTools).
If you are truly the owner of the phone, then use the passcode to unlock it. If you found this device, you should either do everything you can to find the owner or if it’s not possible, wipe it clean.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
Hey @reflectio thanks for the speedy response <3. The home button for the phone is not actually working... It just feels mushy. It worked once but because its mushy it doesn't work. I have tried a screen replacement and a home button gasket replacement but it is still not helping. Is there a way to wipe it/restore it without the home button working? Thanks!
의 답변
Disconnect the battery, connect it back in. When the phone boots, immediately enter the passcode. Once logged in, go to settings\general\accessibility\assistive touch. With assistive touch, you'll be able to use the phone.
As for the button, it should work without a gasket. Check the flex to see if it isn't damaged.
의 답변
@reflectio I have now fixed the home button issue, I swapped the cheap aftermarket home button bracket for an OEM one. I think that I will use this guys service now because I have used him before. Is there a way I can create the backup without access to the passcode? Thanks!
Thank you!
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Rafay Siddiqui 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 23
