주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz) 또는 2.5 (Turbo Boost 최대 3.7GHz) GHz 쿼드-코어 Intel Core i7 프로세서.
465 질문 전체 보기
MacBook Pro mid-2014 15” iSight replacement
Hi, My webcam on my Macbook Pro mid-2014 15” seems to be broken… I tried all methods online to see if its possible to get it back working.. but none of the methods worked. I wondering if it possible to replace the webcam?
I can’t seem to find replacement parts or guide for this model.
Thank you :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
It’s almost an impossible repair, webcam is behind the retina screen and chances to remove it without breaking it to access the webcam are very close to zero, hence the lack of guides or spares, you would have to replace the screen assembly.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
ah... so there is no way of fixing this problem.. any alternative methods?
@Jason Kim There's always the chance the camera is fine and malfunctioning depends on the logic board circuitry, but that needs someone into component level repairs. If it's the camera itself I can't think of any other possible fix than replacing it, but we get back to step one.
댓글 달기
가장 유용한 답변
See step #5 of this guide. Reseat your camera to logic board connector and examine the cable for anomalies:
MacBook Pro 15" Retina Display Mid 2014 Logic Board Replacement
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
귀하의 답변을 추가하세요
Jason Kim 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 23
전체 시간: 2,573
