Is it possible to remove the iMac 5K stand?
Because i want to have a few more air intakes. I have asked a professional (CNC Machining) to add a few more cool air intakes, and to remoce a few aluminium Bars from the hot air “exhaust”.
Similar to this:
https://forums.macrumors.com/threads/ima...
I’ve already changed the thermal paste, cleaned everything and it still runs way to hot.
Update (07/22/2019)
@danj Here’s the TG-Pro screenshot.
좋은 질문 입니까?
댓글 5개
Let's get a better idea what's happening thermally. Install this great app TG Pro When the system appears to be running hard take a snapshot of the apps main window (resize it so all of the sensors & fans are visible) and post it here for us to see 기존 질문에 이미지 추가하기
What type of apps are you running that pushes your system?
How much RAM and how large a drive do you have and how full is it?
Dan 의
It runs with an i7 4790K, 32 GB of 1866Mhz RAM and a dual SSD Setup. The PCI-E SSD with 256GB and an additional 1TB Samsung 860 Evo (with temp sensor adapter).
I mostly use Lightroom. While editing and exporting its a pain. It slows down heavily under load. I'll add the Screenshots as soon as i get home.
MacSpeedie 의
Hey @danj, i already tried everything. The default settings for the fan are way too high. It starts spinning up at around 85 degrees. Under heavy load the Mac heats up to 98-108 degrees. As an electrical engineer i pulled up the Datasheet for my CPU (i7 4790K). It says that the Tcase_max is 72.72 Degree Celsius. Above that Temperature the CPU throttles the frequency quite a bit. For example exporting pics in Lightroom is a pain after one minute it's extremely slow. The first minute it runs okay. It's a design flaw. Also using MacsFanControl to speed up the fan earlier is no solution as the max speed can't cool down the CPU under heavy load.
MacSpeedie 의
The cool air intake is at the bottom. I'll get those wider. And the stand needs to be removed to get rid of the cross members of the exhaust. The iMac Pro has the same cooling design with two fans and an additional cool air intake at the bottom backside of the Mac. It won't mess up the airflow.
I've already taken the iMac apart and reapplied the thermal paste(Thermal Grizzly). The temp dropped by a few degrees but its still way too high. Also did a clean install as i've upgraded the SSD. No improvement. It's a shame! The solution(link) in my question post is the most helpful thing i came across yet.
MacSpeedie 의
@macspeedie - Bingo! You gave me a good clue here. Is the PCIe blade SSD your boot drive?
Can you humor me and give me a TG-Pro screenshot
Dan 의
