My iMac is stuck on a question mark
After installing a new SSD I’m stuck on the question mark and unable to boot up.
좋은 질문 입니까?
좋은 질문 입니까?
Try to hold [alt] while you start the imac and you should see your system. If that was the Problem: Boot it up and go to the System Preferences->Startup Disk and choose your system as the Startup Disk.
해당 답변은 도움이 되었습니까?
@spaeder - The Apple keyboards are marked Option (⌥) as the primary marking.
If Spaeder’s answer does not work your drive likely has become corrupted or has failed. Try Command (⌘) and R keys to see if you can recover your OS, if you can’t you’ll need to get a new drive.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 51
댓글 1개
Here's a reference to the startup key combos Mac startup key combinations
Dan 의
