주요 콘텐츠로 건너뛰기
Not charging when plugged in
Plug turns green, orange then fades to blank in quick succession once plugged in. Not charging.
For the past month or so the charger has intermittently not charged when initially plugged in but would light up and charge after reinsertion.
Not sure if i have a 1.33ghz or a 1.2ghz
(laptop doesn't have enough power to come out of sleep now)
Charger is the original purchased w/ computer in late 04.
45W model# A1036
Battery was still holding a charge for several hours before charger failure
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글:
Thanks for your help, was able to get an after market charger and it did the trick
의견 추가하세요
답변 1개
선택된 해법
To see which machine you have remove the battery and look on the side walls of the battery compartment. I believe the 12" was the 1.2 GHz and the 14" was the 1.33 GHz. Your problem could be the AC adapter or the DC-IN port. By your description I would guess the Adapter.
Here's a variety of original and knock off adapters:
http://www.google.com/search?client=safa...
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
clay 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 699
