no green light on charging cable
macbook pro does not power up/turn on . No green light on charging cable
좋은 질문 입니까?
좋은 질문 입니까?
If that’s the case I would start off by inspecting the systems MagSafe connector making sure its clean and the metal contacts are not burnt.
Here is the replacement MacBook Pro Unibody 13" and 15" MagSafe DC-In Board and here’s the guide to replace it MacBook Pro 13" Unibody Mid 2010 DC-In Board Replacement
Given the age of the system you may also need a new battery MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery and here’s the guide to put it in MacBook Pro 13" Unibody Mid 2010 배터리 교체
상품
$9.99
상품
$69.99
안내서
난이도:
쉬움
10 minutes
안내서
난이도:
어려움
45 minutes
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 40
Review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters. Make sure the cable and the connector are in good shape and you have the correct charger as well for your system. Do make sure its a real Apple chargers as there are many fakes out there! OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth & Real vs Fake Magsafe 2 Charger Macbook Pro
Dan 의
the charging cable works on other macs, not on this one
Greg E Terres 의
